Oil Pressure
Old Dec 10, 2005 | 07:46 AM
stinkyfj60's Avatar
Oil Pressure Gauge
I need to start trouble shooting my oil pressure gauge in my 1984 4Runner. It hasnt worked since I got the truck. I does have power to it, when starting the truck the needle will move from the L position up, but once the truck is started and running it drops and doesnt read. I did replace the sending unit because the threads were bunged up pretty bad and it wasnt tight.
So, when the key is on and the truck isnt running where does the gauge read? I am thinking that the PO may have reversed the plug ins in the back when putting in an aftermarket tach, but kind of want to know that before I tear into the gauge pod.
Thanks!
J
Old Dec 11, 2005 | 06:44 AM
rudestar's Avatar
Sounds like you have an idiot lite oil sender not a oil pressure sending unit. Hook an ohm meter to sender. Gage if defective is easy to replace. I have used gauge for $10 or sender for $5 plus $5 shipping.
Old Dec 18, 2005 | 06:33 AM
stinkyfj60's Avatar
I will check the gauge, I know my sender is correct though, just bought a new one because the one it had was bunged up.
Old Dec 19, 2005 | 05:48 AM
rudestar's Avatar
Is the sender the size of a walnut or a lemon? If it's small it's an idiot lite sender. New the small one is $5-10 and the pressure sender is $35-50.
Old Dec 20, 2005 | 02:57 AM
stinkyfj60's Avatar
It is the size of a lemon and was closer to $50. The one I took off of it matched it. Gauge has power, so I think I will take the gauge out and check the wiring when I can get some time.
Old Dec 20, 2005 | 08:31 AM
rudestar's Avatar
Sender wire is the ground leg of the oil lite, oil pressure opens the circuit turning off lite or in the case of the pressure sender moves a rheostat. Ground the sender wire and see if gauge goes to top. If positive power were to contact sender wire it would burn out sender.
Old Dec 22, 2005 | 03:43 AM
stinkyfj60's Avatar
Great, THANKS! I will check that out too.
bigjstang
Jun 2, 2025 03:56 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
Odin
Jul 15, 2015 09:28 PM
88yodabasket
Jul 13, 2015 01:32 PM
