At what temp will coolant boil?
50/50 mix of ethylene glycol based automotive antifreeze/water is what is typically recommended. The figures below assume a radiatior cap mainting pressure of 11-15psi.
% antifreeze Freezing pt. Boiling pt.
33.3..............0*F.............. 256*F
40..............-12*F...............260*F
50..............-34*F...............265*F
Straight water, no pressure cap=
0 ................32*F ..............212*F
Agreed that it could be the head gasket, but could just be a faulty radiator cap. In fact, you *might* have just happened to look when some of the normal expansion was going into the tank.
The 212F is @ sea level though. The higher the elevation the lower the boiling point, but not by much. For example, at 5000 ft. elevation the boiling point may be 203F vs. 212F @ sea level.
Oh, and if you're getting overheating problems, a stuck thermostat could also be the culprit. And, make sure that you don't have any other coolants mixed with your Toyota coolant. Even a small amount can really throw things off and lower the boiling point considerably.
I pretty much know what caused it....
The dealer had messed up my FAL fan the last time they worked on the truck. Basically, they messed up the power lead and it would lose contact intermittently. The problem didn't show it self until months later. I already purchased a hayden fan controller and was going to install it. I had just gotten off the freeway and was on some side streets and noticed the temp rising, but not in the red. I pulled over immediately and popped the hood. I jiggle the power lead on the fan and the fan started. The coolant in the overflow tank was gurgling. I started the engine to get the coolant flowing through the engine and the temp went back to normal immediately. Dropped the hood and thought everything was ok. The engine was/is running great. I replaced the controller the next day. Today I noticed I have an oil leak on the passenger side under the exhaust manifold. Damn! I just did a valve job on this thing!
Originally Posted by youngbuck
The 212F is @ sea level though. The higher the elevation the lower the boiling point, but not by much. For example, at 5000 ft. elevation the boiling point may be 203F vs. 212F @ sea level ....
Originally Posted by Glenn
Elevation above sea level matters only if boiling occurs in the open because it's related to atmospheric pressure. Since the cooling system is a "closed" system with radiator cap, the elevation above sea level shouldn't have an effect on the boiling temperature.
This is much like a pressure gauge. There's "gauge" pressure, and there's "absolute" pressure. Absolute pressure is the gauge pressure + atmospheric pressure. You could say that the cap rating is a gauge rating, not an absolute.
The cap pressure is determined by a spring. the K value of the spring doesnt change based on altitude. the pressure it takes to compress the spring (and create an opening for it to boil over) is constant (as K values are).
Theirfore I say its an absolute presure not a guage pressure.
Originally Posted by snap-on
I disagree
Atmospheric pressure at sea level, 14.7 PSI + 15 PSI gauge = 29.7 PSI total
atmospheric pressure at 5000 ft, 12.28 PSI + 15 PSI gauge = 27.28 PSI total
The water will boil at a slightly different temp. It's not JUST the force of the spring, but the force on the other side of the spring.
Originally Posted by abalagtas
So if the coolant was only 'gurgling' in the overflow tank...is that considered boiling?
It's supposed to gurgle into the overflow tank as the coolant expands when it gets hot.
I disagree
So unless it was just boiling out the tube, continuously and non stop, it was probably not overheating. No way to tell fer shur from a description, but from what you said that would be my guess.
As a side note, once in a while a younger guy who never had experience with cars before the EPA mandated overflow bottle systems were common would get an old car. They'd get frustrated because it was always losing coolant and they thought it had a problem, which they could not locate. In the old days, the first time you drive it after filling, the excess would overflow onto the ground! (gasp!!!) and next time you check it, it's "low." Fill it up, drive it, it's low.... AH the good old days... That's one of the reasons radiators used to be bigger than they are today.
