3VZE timing belt.. which idlers did you replace ?
Old Nov 28, 2005 | 01:53 PM
nrgetic99's Avatar
Ater reading horror stories about water pump failure, I am going to replace my noisy pump this weekend.
I picked up :
* Pump
* Black sealer
* Timing belt
* No 2 idler pulley (big one)
* Tensioner
As I get a trade account I got all the above for $240 which ain't half bad
Do I really need the No 1 Tensioner ???
I can pick it up and return it if I don't use it but I cannot recall anone here saying they replaced it....
What did you do when you replaced your belt ??
Thanks
David
Old Nov 28, 2005 | 02:01 PM
ChickenLover's Avatar
David
I sure wish I would have. Oddly enough, all 3 of my idlers started to show signs of wear at the same time (#1 and #2 on the timing belt and the one at the very bottom of the accessory belts that acts as a tensioner for the AC).
During my top end rebuild my idlers had no play in them and made no noise when spun, so I did not replace them. Now (10 months later) all of them have considerable play and #1 is actually squealing at idle. If I were you, I'd replace it just to be on the safe side.
Old Nov 28, 2005 | 02:29 PM
eric-the-red's Avatar
I only replaced the #2 pulley when I did the pump on my 93 4Runner, drove it for 2 years after that with no problems from the other idler.
Old Nov 28, 2005 | 02:39 PM
vegaskurt's Avatar
I did both pulleys on my 3.4 when I did the timing belt and water pump. Both did have a slight grind to them when I spun them by hand. Im sure they were years from failing but better safe than sorry. Since you have it apart you may just want to do it.
zd92655
Mar 6, 2022 12:58 PM
voiddweller
19
May 2, 2016 09:10 PM
Ichneumon
Sep 27, 2015 04:21 PM
newzingo
Jun 24, 2015 01:50 PM
infinityisfive
Jun 16, 2015 06:51 PM
