Lift for 2005 Five lug tacoma?
Old Oct 26, 2005 | 07:28 PM
borked's Avatar
Any products out to lift the 2005 Five lug standard tacoma? I've found a lot of places that say they have them, but upon asking in detail. All have said no when it comes to the 5 lug Standard cab tacoma?
Or maybe one of the products that is noted for 2wd prerunners only will work on mine as well? Im really just looking for some like 2.5" spacers. Could I make my own spacers, isnt it just like a large thick washer?
So far i've emailed wheeleroffroad, Toyotech, and tuffcountry.
Old Oct 26, 2005 | 07:34 PM
Rivalred's Avatar
You have a Standard Cab PreRunner?
A PreRunner is 2WD with a 4WD Suspenion and 16" tires. Now I am taking a guess you have a Standard Cab 4WD 5 Speed manual right?
What size tires do you have?
Old Oct 26, 2005 | 08:24 PM
Good Times's Avatar
is the suspension any different from the 6 lug and 5 lug version on the 05+? If not, I don't see why any ol 6 lug lift kit won't work.
Have to tried tacomaterritory.com/forum to see if they have any comments on this? I personally have not seen any 05+ 5 lug suspension setup so I can't really comment.
Good luck.
Old Oct 27, 2005 | 07:21 PM
borked's Avatar
No, it's not a prerunner. It's 2wd.
Old Oct 27, 2005 | 07:22 PM
borked's Avatar
Also in the front it's coilovers, if that helps.
Old Oct 29, 2005 | 07:30 AM
borked's Avatar
bump...
Old Oct 29, 2005 | 09:24 AM
Rivalred's Avatar
Coilovers as in you can lower/raise the front suspension or do you mean a strut with shock which is OEM?
Old Oct 29, 2005 | 10:39 AM
Good Times's Avatar
i think he means coil and shock. i don't think toyota would make a diff suspension setup on the taco so i suspect any 03+ 4runner / 05+ taco suspension lift kit will work.
Flying91
45
Apr 11, 2024 04:39 PM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
Yotoder865
Jul 9, 2015 07:51 PM
akaphilly
Jul 9, 2015 02:18 PM
