Why would the rear wheel turn when gear is in neutral?
Hi All,
I jacked up the rear axle for brake shoe replacement, and noticed that when I turn on the engine, with gear in neutral, the two wheels turns slowly (probably 2 revs per min). If i step on the gas (gear still in neutral), they turn a little faster, but slower than if in gear.
Why would the wheels (propeller shaft) turn when the gear is in neutral?
I have 98 4runner, v6, 4wd, 5spd, no mods.
Thanks in advance.
Thanks in advance.
Originally Posted by mike_d
there's probably enough drag caused by the gear oil that tranfers just enough torque through the transmission to turn the wheels slowly.
Originally Posted by kyle_22r
kind of like the same idea behind a torque converter in an auto tranny or the fan clutch on the motor.
Years ago, I had a '79 Chevy K10 with the old 4 speed manual with the 'granny' 1st gear. Where I usually parked at my home was on level ground, so I didn't normally set the parking brake. I learned the gear oil drive lesson very well when I left it idling one VERY COLD morning (about 15 below) before I went to work. I had started it to warm it up, and went back in to get my road coffee. When I came out, the truck was gone..........
I found it on the front lawn next door. The 90 weight was so stiff, it 'drove'
the truck about 80 feet until it decided to stop on its own. Used the parking brake a lot more after that
cchinny
Jun 25, 2015 08:11 PM
Mr.Black
Jun 21, 2015 10:17 AM
AustinTaco
Jun 21, 2015 09:54 AM
