A ? for Dr. Z... 7mm Magnecor wires
Old Feb 21, 2003 | 03:06 AM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
Question A ? for Dr. Z... 7mm Magnecor wires
Dr. Z:
Do the 7mm Magnecor wires fit the stock wire looms? I was considering upgrading, but want to be confident that the Magnecors will fit the looms for a clean look.
Thanks,
Rick
Old Feb 21, 2003 | 06:45 AM
Dr. Zhivago's Avatar
Away
It's a tight squeeze, but yeah they fit. If you buy the 8.5's, I am pretty sure they give you new wire separators.
Hope this helps.
Dr. Z
Old Feb 21, 2003 | 07:33 AM
Rick F.'s Avatar
Thanks for the response. Certainly apprecited.
Old Feb 21, 2003 | 10:25 AM
I have the 8mm Magnecor wires. Zip ties will work too
Old Feb 21, 2003 | 10:28 AM
rimpainter.com's Avatar
Not to "poke my nose" in on this thread or anything, but I heard that plug wires touching is a bad thing. So, my concern would be for Dukestr's set-up. Yeah, I realize those are pretty heavily insulated wires, but they are touching, and I was told that can cause possible misfiring.
Someone please correct me if I am wrong, I have no data to back this up. Its just something I heard.
Old Feb 21, 2003 | 11:07 AM
Away
You are correct sir! That can be a bad thing, especially on lesser wires. I'd use separators myself, but if the Duke isn't having any problems, he's probably ok. But if he starts getting misfires and other oddities, he knows where to look first!
Dr. Z
Old Feb 21, 2003 | 12:25 PM
Yup, this is also why you see wires "twisted" around each other at some point, in some engines. That helps to cut down on them interfering with each other. A bit less cosmetically appealing, but function over form I say. They still look sweet, even if they have to twist around (almost like a funky braid) at one point.
Old Feb 21, 2003 | 12:54 PM
pfdaxe's Avatar
Here's a couple of pics of my blue 8mm Magnacors:
http://groups.msn.com/2000SR5ToyotaT...oto&PhotoID=62
http://groups.msn.com/2000SR5ToyotaT...oto&PhotoID=31
80Truck
Oct 12, 2025 07:25 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
ToyoToler
Aug 8, 2015 08:43 AM
Mrhoadley
Aug 4, 2015 06:08 PM
Daneums
Jul 28, 2015 11:57 AM
