Any issues with larger tires??
Hey guys,
I just recently installed 285's on my runner and thought i'd ask about the change in my speedometer readings. From what i can tell, theres barely a difference, but i could be wrong. Is it neccessary to have my speedometer re-ajusted after adding these larger tires? Any other important things I should be aware of due to the larger tires?
Any help would be great, thanks.
-Micah
-Micah
Yeah, here is a nice tire size calculator that will let you know that if you went from a 265/70R16 to a 285/75R16 tire, for example, your Speedometer Difference: would be 7.292% too slow.
http://1010tires.com/TireSizeCalculator.asp
Alright, thanks for the help guys...I used that calculator and learned that if my speedo showed 60 mph i'll actualy be going ~64mph...I want to get this fixed, so do i just go to my local stealer or to someone else to have my speedo redone?
Thanks again,
Micah
Thanks again,
Micah
well, a better solution that is more popular on here is to regear, which will give back lost power from bigger tires, and will also return the speedometer/odometer to very close to stock reading. but, then comes all the other things with that, such as you HAVE to regear the front also, and then, while you're regearing, might as well put lockers in to save $$ on labor. the price will add up quickly, and if you're not willing to pay all that right now, just have your speedometer changed, i dont know where though....
Not necessarily, b/c if that was true then my speedo would be reading fast instead of slow.
28.4" tires and 3.91 gears stock vs. 32.8" tires and 4.88 gears now
Originally Posted by supahonkey
4.88 gears wtih 32.8" tires? That sounds like the gear ratio is crazy. I did a SAS on my 02, manual, yaddy yaddah, 4.88s with 35s, and i'm back to stock power.
Got any pics of that SAS? I'm assuming it's a Tacoma?
Originally Posted by ErikJeanna
What would you gear if you only planned on running 33's (maybe 34's)? I was planning on a 4.88, but would a 4.56 be more realistic?
FWIW I am very happy with my stock 4.30s and 285s. Granted I have a s/c, but there is still plenty of power. If I had 4.10 I would go to at least a 4.56 unless you can find a deal on stock 4.30s and e-locker
Originally Posted by kryptik
Mine is a good 15-20mph off on highway speeds. But atleast if I get pulled I have a semidecent excuse.
Flying91
45
Apr 11, 2024 04:39 PM
djpg2000
Nov 11, 2020 04:56 AM
