Oil Pressure question.
Old Aug 25, 2005 | 12:24 AM
HurleyBoy's Avatar
I have a 94 22R-E Pickup. I just now started to notice something, My oil pressure used to be right in the middle of the gauge during normal driving, However now its lower than usual when I drive normally. If I get on it it was rise up and sit where it normally does but then drop back down. is my oil pump going out or could be it that im low on oil or need to change it?
Old Aug 25, 2005 | 04:47 AM
ken.vs.ryu's Avatar
are you low on oil?
Old Aug 25, 2005 | 05:36 AM
Bumpin' Yota's Avatar
sounds like my 3vze....lol
Old Aug 25, 2005 | 05:44 AM
sandcrawler's Avatar
this is a pretty common thing ... the consensus seems to be that these engines don't need a lot of pressure, just enough oil in the sump.
i'd check to see if you have any leaks, and if you're in fact low on oil. if things look ok, just keep watching.
Old Aug 25, 2005 | 11:26 AM
the toyota FSM claims that 4-5 psi at warmed up idle for the 3vze is normal.
Old Aug 25, 2005 | 02:44 PM
Flamedx4's Avatar
All of my Toyotas (and my fathers too) have done that when they are either a quart low (seldom) or due for an oil change. Like clockwork, the pressure would drop at idle after 3 to 4k miles - time for oil change. Dunno why, I think it's probably something like because the oil filter is getting clogged and the bypass is now working - and this causes a pressure difference at idle that isn't normally there.
bigjstang
Jun 2, 2025 03:56 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
Odin
Jul 15, 2015 09:28 PM
88yodabasket
Jul 13, 2015 01:32 PM
