GPS & Communication Discussions here pertain to the use and troubleshooting of GPS, CB radio, and amateur radio
Why Firestik vs other antennas?
Old Aug 15, 2005 | 12:39 PM
Crux's Avatar
Isn't the Firestik for trailers or semi's that don't have a metal ground plane?
Seems like a 4Runner has a lot of metal...
While talking with a local radio shop they recommended getting a regular steel/wire antenna (with the coil at the bottom) over a fiberglass Firestik for better reception.
Old Aug 15, 2005 | 01:15 PM
AzStorm's Avatar
Firestick makes a no ground plane antenna commonly used in applications where there is little or no metal,IE: fiberglass motorhomes/trailers etc..
A base loaded or coil at the bottom antenna works ok as does the standard firestick.They are both prevalent due to their affordabillity and availabillity.
The best mobile CB antenna I have ever used is a Predator 10K with a stainless steel 108" whip coming in a close second place.
I'll gladly answer any questions you might have if youll shoot me an e mail.
AzStorm@gmail.com
zombie_barbarossa
Oct 2, 2015 10:54 PM
tazman1972
11
Sep 28, 2015 10:32 PM
Ilovemountains
Sep 15, 2015 04:17 AM
Peevedkitten
11
Aug 31, 2015 06:57 PM
msged2007
Aug 22, 2015 07:46 PM
