Sudden Bucking and Popping out of Gear
Old Jul 21, 2005 | 09:12 PM
Scofco's Avatar
This has been happening more frequently and it's time to do something about it before it gets any worse, I just don't know what exactly it is in the clutch system that's causing it.
I'll be driving and the truck will suddenly jerk forward and the resume as normal. Sometimes I'll be driving and the transmission will pop out of gear, usually in 1st gear. Othertimes the gears will grind and not go in at all, it almost always grinds when going into reverse.
I was told the truck had a new clutch put in about a year and a half ago.
What would cause this?
Old Jul 21, 2005 | 09:18 PM
superjoe83's Avatar
the fact that it pops out of gear is definitely a trans problem, is the shifter sloppy?, as for the grinding it could be the clutch, does it always grind when going to reverse, when i got my '84 the clutch was shot and wouldn't disengage all the way, i think that the pressure plate was warped and always was dragging on the disk, sounds like you have two problems
Old Jul 21, 2005 | 09:23 PM
superjoe83's Avatar
and maybe try bleeding the clutch and make sure that the floor mat is not under the clutch pedal, that will cause it not to release all the way and could be one of your problems.....
Old Jul 22, 2005 | 12:51 AM
Greg'sToy's Avatar
your shifter seat and bushing could be bad...i had almost the same problem. my bushing was nothing but little bits and pieces when i checked it. you have to the the shifter off to check it.
Old Jul 22, 2005 | 10:26 AM
Flamedx4's Avatar
Mine did that and the shifter seat bushing and the bushing on the tip of the shifter fixed it. Under 20 bucks - gotta like that.
Old Jul 22, 2005 | 03:39 PM
Scofco's Avatar
I replaced the seat and the bushing already a couple months ago, and it's not the floor mat either.
Looks like I'm in for some $$$ spending
Old Jul 22, 2005 | 03:55 PM
Flamedx4's Avatar
OUch. Thats a bummer.
Old Jul 22, 2005 | 07:26 PM
89macrunner's Avatar
i have the same problem scofco
let me know what the fix is and importantlly..how much the fix is
mskalmus
May 28, 2017 07:51 AM
pyramid
Jul 30, 2015 10:05 AM
Backcountry411
Jul 24, 2015 08:06 AM
PlayAwhile
Jul 20, 2015 11:36 AM
mengquis
Jul 13, 2015 10:39 AM
