1st Gen 4ruuner Frame Swap
Old May 15, 2005 | 03:01 PM
BuzzLitebeer's Avatar
I have an 87 4runner and I am about to purchase another 4runner that has had it (body has more holes than a block of swiss and the engine and tranny exploded long ago), I am not to sure but i think that it is an 84. Is it possible just to swap the bodies and engines from one to another?
Old May 15, 2005 | 04:02 PM
93ToyKid's Avatar
Should be no problem
Old May 15, 2005 | 04:31 PM
superjoe83's Avatar
are you talking about putting your 87 body on a 84 frame? is so, there are some differences, the biggest one is that the 84 frame has a solid front axle, which will work fine if you get a solid axle front drive shaft, you oil pan may or may not work with the 84 frame, never seen a ifs pan so I'm not 100% sure, the gas tank may be different because its a carb tank, not a problem if you use your tank and fuel lines
Old May 15, 2005 | 06:39 PM
I am just being lazy and I don't have anyone around that will weld for a decent price for me to do a SAS with the 87. So I figure that I can find a 4runner that has been hammered through and just swap bodies and engines to get my solid axle.
Old May 16, 2005 | 08:06 AM
Lt. Dan's Avatar
Tne oil pan on an IFS is different from a solid axel. The pumpkin on a solid front axel WILL hit the oil pan from a IFS. Guess how I know....go on.... guess. Dent in the oil pan...damaged seal...oil all over my driveway....Grrrrrrrrrr
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
steve miller
Oct 10, 2015 01:40 AM
coryc85
Jul 6, 2015 04:07 AM
CJ94yota
Jul 3, 2015 10:14 PM
