unbeleivable smog check, 3100 points over HC
Old May 14, 2005 | 02:01 PM
2WICE's Avatar
Guest
From: Las Vegas.. Soon to be heading for south america in the 4R
got my truck smogged today for registration.. and if failed miserable..
scored a 3346 for HC at 2500rpm, and 3215 for HC at idle.. in order to pass its suposed to be under 220..
any ideas?
Old May 14, 2005 | 04:04 PM
4Crawler's Avatar
http://www.interro.com/techgas.html#anchorfour
Old May 14, 2005 | 04:35 PM
2WICE's Avatar
Guest
great info.. thanks.. i thought i was having some misfire issues.. now im kind of sure..
im gonna take it into a shop on monday... thinking bout a new ignition wires and plugs anyway.. so this might be the straw that busts my wallets back..
Old May 14, 2005 | 04:40 PM
4Crawler's Avatar
Fresh oil change as well and make sure the engine is good and hot, drive 10-20 miles at speed (at least) before retesting. Check your O2 sensor or replace if it is old (I keep a brand new sensor just for smog tests).
Also consider adding 10% denatured alcohol to the gas tank. Adds O2 to the fuel, helps reduce HC/CO levels, also make sure your timing is fully advanced.
Old May 14, 2005 | 05:32 PM
2WICE's Avatar
Guest
thanks for the tips...
how do i advance and retard timing correctly on a 3.0?
2WICE's Avatar
Guest
never mind.. i shoudl eb able to find that on my own..
Old May 14, 2005 | 06:16 PM
4Crawler's Avatar
You'll need a timing light to check and set the timing.
kgcwb44
Jan 29, 2023 10:02 AM
Sleaker
Aug 26, 2020 06:03 AM
jasonty
41
Dec 23, 2018 01:00 PM
v_man
Jul 23, 2015 04:01 PM
timmJ
Jul 7, 2015 02:01 PM
