Gas Pedal Sticking
Gas Pedal Sticking
The gas pedal on my 2000 4Runner often sticks when you first push on the gas pedal to start moving, not during acceleration. I checked out the cable and can't see any glaring problems. Has anyone had a similiar problem? Any suggestions? Thanks
sounds like the spring on the pedal might be catching, or gunked up? if not that, check the throttle body. it may need a good cleaning
From: Far western Kentucky (transplanted from central PA)
Clean your throttle body. There should be a write-up about it. The varnish tends to cause the butterfly valve to stick and it usually breaks free when you first touch the accelerator and then is usually ok while your driving. It'll stick again after sitting for awhile. It's easy to do and will save you about $60 from having the stealer do it.
DiZ86
Dec 27, 2015 09:33 PM
AppalachianOffRoader
Aug 12, 2015 12:55 PM
D.B.T. 87 4x4
Jul 20, 2015 04:51 PM
