3rd Gen Rear Latch
Old May 8, 2005 | 07:21 AM
3rd Gen Rear Latch
I can't get the 'search' to work so forgive me...
The rear door latch on my 'Runner has died, I've had some self resolving problems with it before but this time it won't open the hatch at all. Is there anything I can look at fixing here, are parts involved or do you think something is just out of place?
Thanks,
Emil
Old May 8, 2005 | 11:15 AM
ScottyBean's Avatar
will it not open because the latch is stuck open? if thats so just push it down. I find when I open my 96, it gets stuck full extended, and when i try to close it, it doesnt. It will just bang off and off until that latch is popped back in place.
Old May 8, 2005 | 01:02 PM
Bob_98SR5's Avatar
emil,
most likely your latch mechanism's nuts are loose. see the attached pic. the two nuts on the side are worth looking at.
to remove the rear plastic panel, remove the strap w/ a 10mm (iirc) socket and then remove the plastic panel. they'll snap off so dont worry (red snaps). then inspect the nuts and see if thats the prob
bob
Old May 9, 2005 | 05:17 AM
TaterN's Avatar
Wyoming>>>
I have the same problem as you, at least it appears. I'll add one more detail that you may have missed that is confusing those trying to help. On mine anyway something has definately broken. The latch trigger has practically NO tension when you go to open the rear door. Something (rods probably) has broke or come loose here...it usually takes a good firm pull for that trigger to open the closed hatch. There is no "pull" now.
While I do some more searching, I just hope the rear window keeps working!
Bob>>>
What you are describing is probably the problem. If the bolts come off though, are they easy to fish out of the bottom of the door? I've never been into that rear door yet.
Old Sep 14, 2005 | 10:58 AM
Bob_98SR5's Avatar
...since this thread is being referenced recently, i'll answer tater's question above:
yes, if the nuts have fallen and you've removed the plastic panel, it is easy to get at the fallen nuts
bob
Old Sep 29, 2005 | 09:56 AM
bamachem's Avatar
see the white plastic thingy in the pic posted above? that's a rod retainer and if it breaks, then the actuator rod will slip out and you won't have any linkage to the latch mehcanism. replace it (avaialbe at any auto parts store or the dealer) and you'll be good as new.
Old Oct 19, 2005 | 05:31 PM
gonzopb's Avatar
I am having a similar problem but the latch is all the way out and the door is still shut. The latch is stuck in the out (open) position.
Old Oct 19, 2005 | 09:58 PM
Bob_98SR5's Avatar
referencing the pic above, did you remove the plastic panel and see what the problem might be?
Old Jul 31, 2011 | 07:04 AM
skirkup535's Avatar
Tailgate interior light on after fixing loose nuts on latch.
Hi, I know this an old post but it helped me. I just checked why mine wouldn't open easily and found the loose nuts, tightened them and locked in place with blue locktight. Prior to doing this I cleaned the latch with brake cleaner and lubed with WD-40 and also cut off some of the plastic coating on the latch that was torn and making it bind up. Now it latches fine and opens everytime. But now the interior light stays on. I was thinking the WD-40 screwed up the contacts in the latch. Any thoughts?
Old Jul 31, 2011 | 08:45 AM
skirkup535's Avatar
Answered my own question, took it all apart again and sprayed heaps of contact cleaner in the latch where the wires lead in. All set.
Old Jul 3, 2013 | 11:44 AM
zumogo's Avatar
It's a old thread but it help me
Mine wasn't loose but it looked dry so I spray some wd40
I hope it would solve the problem, since it's been acting up lately.
Now it works again
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
jerusry
Oct 19, 2015 05:28 PM
noahstancik
Jul 17, 2015 05:38 PM
tpd143
Jul 7, 2015 09:06 AM
