All-Pro Adjustable Rear Control Arms on a 3rd Gen?
Anyone using these on a 3rd Gen? The site only indicates they are for 2nd Gen. Can anyone tell me if the upper control arms are different from 2nd to 3rd gen?
check out spidertrax....and also check out www.sonoransteel.com for info on both the spidertrax arms and other options. Click on his 4runner link in the upper left corner.
Brian
Brian
Unless I am mistaken, Steve's site shows lower arms...I need upper. Also I can't find any on www.spidertrax.com Am I missing something?
The links are not on the Spidertrax site anymore. People have used Heim upper links but, for most of them it was a failure. You may try cutting and sleeving the link to change the length.
I think I kinow what your thinking here, adjust the rear U-joint angle. I have never messed with it and the factory settings have always been fine for me, even with my current 4.5" of lift.
Sorry no help from me.
Thanks anyway Steve. It's not like you haven't helped before. If I had a double cardan joint at the trans end, I wouldn't have this problem. I think my pinion angle is about 1* too high. I need to point the angle down that amount. I will check with my welder to see what he thinks.
Jun 1, 2021 01:51 PM
jerusry
Oct 19, 2015 05:28 PM
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
Sep 9, 2015 06:24 AM
tpd143
Jul 7, 2015 09:06 AM
