Tacoma stock height?
Hey gang, my trucks suspension was beat when I got it, so I'm curious How much higher than STOCK, as opposed to 8 year old stock, I am. I don't figure it changed much 95.5-04, so can someone tell me the stock height, front and rear (at the wheel-well would be cool, or bumper) of V64WD (xtra cab if makes a diff) tacoma, anything from those years. The rear starts out higher, right?
(BTW, I did do a search, found heights for a bunch of gens of runners, and on older truck, but no tacos).
spanks,
Ian
spanks,
Ian
You're in luck!
I just found this the other day.
I went to the local dealership a few years ago and wrote down what the stock height (peak of wheel well from ground) was on a double cab V6.
Driver front - 35"
Driver rear - 36.5"
Passenger front - 34.5"
Passenger rear - 36.4"
I didn't get a chance to check out the tires' PSI so these may be off what they are supposed to be. Hope it helps you out!
Driver front - 35"
Driver rear - 36.5"
Thanks Tacoma Dude!
Thanks man, sounds like tire pressure was a little low. Mostly I wanted to know how much higher the back is stock-I'm about done with my lift and it looks like it will be about 1.5 to 2" higher in back (without the cap or spare or hi-lift), so it seems like the front to back ht. diff will be close to stock.
I'm okay with the back being a little higher empty, I haul stuff quite often (lumber, quikrete, firewood, dogs, etc) and it'll be nice not to bottom the springs out everytime I load up.
Last edited by ianshoots; Apr 8, 2005 at 09:25 PM. Reason: can't type after midnight
Flying91
45
Apr 11, 2024 04:39 PM
WTB[PacNorWest]: WTB - Tacoma/4runner 3.4 Charcoal canister and igniter
94whiterunner
Jul 12, 2015 07:15 PM
Poncho0206
Jul 10, 2015 06:21 PM
