I need help with rebuilding the aisin manual locking hubs for 86-95 IFS
i am buying a pair(used) of the aisin hubs to replace the A.D.D. on my 4runner. i was thinking that since i have them off and if it isnt too hard i could rebuild them and paint them and make them look and work like new. i was also wondering if anyone had a pic of all of the nessecary hardware so i know that i get every little piece for the install. thanks
they are a peice of cake to rebuild. all you do is take them apart and replace 2 gaskets and clean everything up. when you take them apart to paint make sure you do NOT loose the ball and spring. i lost my spring, but i had a spare set of hubs, so i just used the other hubs. hope it all works out
Originally Posted by surelly09
whats the spring and ball bearing do??????? i mean why are they there?
Try your local dealer...
http://www.marlincrawler.com/axleparts.html
or any other place that sells Toyota parts...shouldn't be hard to find at all.
Here ya go
http://www.pnw4runners.com/pdf/AisinHubs.pdf
found it in this thread
https://www.yotatech.com/forums/show...&highlight=pdf
These might help you out also....
http://www.autozone.com/servlet/UiBr...3d80161e76.jsp
http://www.4x4wire.com/toyota/maintenance/front_end/
make sure you get those springs in just right
is this on the truck or off the truck that you can't turn it to lock?
Co-Founder/Administrator
That link that S_wall linked to my site is from the "CD" version of the FSM.
