please critique my suspension package I just ordered
Any comments on the new suspension I ordered last night? I will be putting this on my 1999 4runner 2wd v6 that is still running the stock stuff with 150k on the odo. I didnt get the extended studs or diff drop because I am just looking for a better than stock ride, not really a huge lift. Am I missing any critical parts? Should I get new springs isolators etc?
Items Ordered:
Item: COIL SPRING, Tundra, 4WD, Right, Access Cab, w/Off Road Pkg. 2000 - 2002
Item: COIL SPRING, Tundra, 4WD, Left, Access Cab, w/Off Road Pkg. 2000 - 2002
Name Code Qty Each Options
Front Shock SUOME-N91S 2 102.71 Select shock type = Firm Valve;
SUOME-N91S
Rear Shock SUOME-N86 2 71.90 Select valve = Firm Valve;
SUOME-N86
Rear Spring SUOME-OME890 2 65.92 Select spring = Standard Duty;
SUOME-OME890
ADDCO Front Anti-Sway Bar #573
ADDCO Rear Anti-Sway Bar #483
Energy suspension 001 ENS-9-5161G
Energy suspension 001 ENS-9-5165G
Items Ordered:
SUOME-N91S
SUOME-N86
SUOME-OME890
Originally Posted by gapguy
Looks good. You may be a little bit nose down with that setup, but you wont know until its all together.
Let us know how you like the swaybars...
BTW don't forget the panhard drop!
he should be fine up front as well. he's 2WD, so he's about 150# lighter than a 4WD. that would relate to a slightly higher stance, but still less than 1/2".
IIRC, the 890's are good for about 1.5". he should get 1.5" from the front Tundras. Make sure to re-install the rear conical bumpstops to get an extra 1/2" in the back for a perfect stance...
Also, for a better ride, take a saw and trim off the lower "puck" from the conical bumpstop. It will result in a much-improved ride that will bottom out less.
thanks for the feedback guys. used the almighty Search button and it looks like I'll be ordering one of the panhard drop bars tonight from Steve. I hope the wife likes her new suspension. Now I'm just waiting for the motor to go so I can do a fresh rebuild and a supercharger.
Nice! See this thread and let me know if you have the same problem. Thanks!!
https://www.yotatech.com/forums/f2/ome-lift-installed-driveshaft-vibration-51725/
I would try the Tundra coils without the top out spacers. Since your lifting a 2WD, you will not have the weight of the front diff or any sort of aftermarket bumper and winch.
Other than that it looks like you have everything.
Originally Posted by mycotopian
I was going based on this ^^ Can anyone else confirm that the 2wd can't or won't need the panhard drop?
Originally Posted by ORB
He said you don't need, nor can you even put the DIFF drop, the panhard is something else and a good idea (although also not mandatory).
Over time, with the axle shifted, the passenger side upper stud will eventually break off.
Originally Posted by sschaefer3
It is if you don't want to break the stems off of the OME rear shocks.
Originally Posted by Albuquerque Jim
I support that theory
, I was just pointing out the fact that some people say it's not NEEDED...
WHOOMP
Here it is. Its a little stiffer than it used to be obviously but it handles awesome. I cant wait to throw the new sway bars and end links in
Now do you guys have any suggestions to fill those huge gaps? Remember this is the wifes grocery getter so something street oriented. I was thinking maybe the lexus wheels or TRD 20" wheels but those are over $2k.
