99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
Old Apr 5, 2016, 11:32 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tundra Transmission Guides
Print Wikipost
Diff. Oil for LSD Thundra rear ends?
Old Mar 21, 2005 | 11:31 AM
Ben03's Avatar
The first time I bought the LSD additive from Toyota for $6+ and found it for under $4 at the Pep Boys, and at the same time I used a LSD oil from Castrol that says it is for LSD rear ends. I read every label on every gear oil in the store and some said it was for topping off LSD's and others said it can be used in LSD's. Well this time I didn't put the additive in and believe that as on the Castrol label it reads twice that is is for LSD's that I don't need to use any additive.
Any of you use this stuff or anything else so long as it says it is LSD safe?
LSD is Limited Slip Differential, not Lysergic Acid Diethylamide for the wise guys out there or children of the 60's.
Old Mar 21, 2005 | 01:51 PM
Mohamed's Avatar
I change my fluid with Redline in the rear, already has friction modifers added in the fluid.
The front and tranfer case, I used Amsoil in my last change.
Old Mar 21, 2005 | 04:33 PM
TACOMANATOR's Avatar
I use Mobil 1 in my diffs and it has the additive in it, but I don't have a LSD, I have a locker.
Old Apr 17, 2010 | 07:55 AM
carmellocafe's Avatar
Look out for Mobile 1 Synth.
I've heard many people having problems with using the Mobile 1 LS gear oil in limited slip differentials--Causing chattering/shudder. It seems that most have been able to correct the problem by just switching to conventional gear oil and adding in a tube of friction modifier.
Old Apr 28, 2010 | 09:36 PM
wonshot1's Avatar
Anybody try the Purple stuff? It ain't cheap but they make alot of claims about how great they are.
Old Apr 29, 2010 | 01:16 PM
Bullet99's Avatar
Amsoil, period. In the engine, diffs, xfer case, trans.
Old Jan 5, 2013 | 04:30 PM
Ben03's Avatar
It has been a while but I think I'm going to change the LSD fluid again as my truck now has 112,000 miles and it is time.
I may get some cheap 75w-90 and a 7oz tube of TransX and see how it does.
bigjstang
Jun 2, 2025 03:56 PM
Colington
Mar 8, 2020 09:51 AM
icentropy
Jul 9, 2015 02:12 PM
Gamble_STi
Jul 7, 2015 07:54 PM
toyoda8488
Jul 5, 2015 10:18 PM
