Largest tires that will fit my stock 82?
Old Mar 3, 2005 | 07:38 PM
futurerunner's Avatar
Well the easiest way to change the final gearing is....you guessed it...Larger tires!
Yeah Yeah, I know. Poor fuel mileage blah blah blah.
So, what is largest tire I can fit under the 82yota without rubbing the fenders. Keep in mind I really have little articulation in the axle given stock everything.
Ok, thanks.
Old Mar 4, 2005 | 07:24 AM
kyle_22r's Avatar
32s should fit without rubbing. you could run 33s but you'll rub on turns.
Old Mar 4, 2005 | 10:17 AM
retardedspleen's Avatar
33s will rub on higher speed turns (when the truck articluates to one side) and if your wheels are turned when you go over a bump (like pulling into your driveway?) if you get 33s take your tires off and trim the inside of the fender a little , just the seem...maybe take a hammer and pound it in a little...but no bigger than 33's and be carefull off-road
Old Mar 5, 2005 | 07:06 AM
32's sound good. Thanks.
Flying91
45
Apr 11, 2024 04:39 PM
djpg2000
Nov 11, 2020 04:56 AM
XtraCab
Apr 12, 2020 05:25 AM
coffey50
Jul 28, 2015 10:55 AM
DrZero
Jul 13, 2015 09:59 AM
