MAF sensor messed up by K&N FIlter...!!!
99 4runner, v6 5spd put a K&N in it, and a little while after, started getting check engine lights on and delayed response to the throttle. Ended up being the MAF. I had to get it replaced. ...theres talk about cleaning them, is this true?> and could i do it myself? if not, how much on avg it would cost me?
yeah man, you can clean them using an electric contact cleaner... or like what i did... a little rubbing alcohol and a q-tip. At worst there are lots of people on this board and on ebay selling used ones for under 20 dollars! goodluck
Originally Posted by kris
I have seen the oils in the K&N ruin quite a few MAF sensors. They just seem gunk them up pretty bad.
Here you go on the MAF sensor cleaning:
http://www.4x4wire.com/toyota/mainte...tenancep5.html
Sell the K&N on eBay and get an Amsoil....too many have had K&N foul their MAFs.
From: Far western Kentucky (transplanted from central PA)
Oiled air filter + MAF = MAF cleaning
I typically throw a CEL requiring MAF cleaning once between every clean/reoil cycle. Sometimes twice, depending on how well (or not so well) I blot the excess oil from the filter.
Originally Posted by FilthyRich
you are using too much oil. There is no need to saturate the filter for the oil to be effective. I would guess that continuing like that will destroy your MAF
Dont use the squirt tip they give you. Put on a spray cap and just give it a light "dusting". Use as little as possible.
Originally Posted by snwbrdpunk16
mine makes a weird rattling type sound when i step on it in a higher gear at lower speeds when the RPM's are down. If i clean it would the maybe help??
Good time to run some seafoam through the tank and clean the throttle body while you are at it.
From: Home: Aurora, CO; Work: The People's Republic of Denver
That's why I went back to an OEM filter every 5-10k, no chance of MAF sensor oil contamination with it.
BTW, I have an Amsoil filter for anyone who wants it for FREE. I'll even throw in the new oil spray can I just bought.
Cheers,
P
Sure, I sold a CB to Matt several weeks ago. Have him PM me and I can box it up and mail it to him. I'll clean it before I ship it.
Seatbelts
7
Aug 29, 2015 11:48 AM
Tacoma1313
Aug 17, 2015 05:44 PM
Koolbananass
Aug 12, 2015 01:59 AM
