Do 3.0L TD headers and turbo fit 3.0L gas engines?
Old Jan 12, 2003 | 07:45 PM
DH6twinotter's Avatar
Hey all,
I was just brainstorming a bit. Would the headers and turbo from a 3.0L turbo diesel (they do make a 3.0L diesel, right?) bolt up to a 3.0L gas block? Might be kinda interesting. Do these engines use the same block, etc?
I wonder what the power increase would be.
You all's thoughts would be cool.
Have fun all.
DH6twinotter
Old Jan 12, 2003 | 08:01 PM
tomus1000's Avatar
I doubt it. Diesel motors are not at all like gas jobs. Plus, where are you going to get turbo diesel parts from?
Old Jan 13, 2003 | 03:07 AM
gwhayduke's Avatar
The 3.0 diesel is a 4-cylinder if I remember right. The 3.0 gas is a V-6.
Even if they had the same configuration, since the diesel operates at much higher chamber pressures, when the exhaust would get dumped into the header, it would expand and create a larger volume of gasses than the gas version. Hence, you'd need a much larger header and exhaust pipe to keep the back pressure at an acceptable level. Check out the pipe on Ford/Chevy/Dodge diesels and compare them to a comparably sized gas V8...the diesel will be larger.
Yota.Jay
Jul 23, 2015 08:08 PM
Cplmike
Jul 8, 2015 08:47 PM
Jnkml
Jul 6, 2015 01:20 PM
wilbertd
Jul 6, 2015 07:39 AM
karbin
Jul 5, 2015 11:37 PM
