Panel fuse keeps blowing on 98 Tacoma
Old Feb 21, 2005 | 06:00 PM
The Captain's Avatar
Ok, so I am comming home from class today and I went over this bump (damn Illinois roads suck, feels like your whole car is gonna shake apart). Well, as soon as I go over the bump, my dash lights go out. So I'm thinking that somehow or another maybe the switch for the headlights got turned off, but they were still on. So I pulled over, checked the fuse, and sure enough, the panel fuse was blown. Well I replaced it, but figured it would just blow again, and it did.
So, anyone know what in the world could be going wrong? I am guessing something is shorting out, like a lose wire just grounding out. I have no idea, and it really pisses me off. Thanks for any help!
Old Feb 21, 2005 | 11:20 PM
wrenchmonster's Avatar
Sounds like you're grounding out somewhere, or have a poor connection. Find out everything attached to the fuse that is blowing. Then check your circuitry from there. From your description, it sounds like you may have a vibration problem. Once you figure out what circuits are attached to the fuse, you may opt to put in a circuit breaker where the fuse was and then move the associated harnesses and see if your problem can be re-created. Good luck.
-Wrench
MO transplant
Apr 23, 2023 11:58 AM
theking11863
Mar 19, 2016 09:36 PM
PlayAwhile
Jul 20, 2015 11:36 AM
rushw
Jul 18, 2015 01:46 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
