Swaybars?
Old Jan 25, 2005 | 02:35 PM
YotaTruck1986's Avatar
Question Swaybars?
I swear this my last suspension question thread .
Does anyone have any expeirence with swaybars? Is it worth the $300 for a front and rear sway bar? How difficult is the install? I'm considering these: Front Swaybar & Rear Swaybar
Thanks for any help!
Old Jan 25, 2005 | 02:47 PM
Cebby's Avatar
If it isn't a larger diameter than stock, you won't notice any diffference in cornering. You can replace the rubber bushings on yours with polyurethane and will get a little improvement for not too much $$.
Old Jan 25, 2005 | 02:51 PM
So my truck came stock with front and rear sway bars?
Old Jan 25, 2005 | 02:52 PM
Cebby's Avatar
Should have. Ever looked under there?
Old Jan 25, 2005 | 02:53 PM
I have, but I never would of recognized them.
EDIT: On a second look, I'm pretty sure I don't have a front or rear swaybars.
Old Jan 25, 2005 | 03:12 PM
Flamedx4's Avatar
Did the 2wd have a rear sway bar? Don't think so, nothing had a rear one until later model 4Runners got a rear bar.
I'm pretty sure you should have a front one though. Looks similar to this:
Old Jan 25, 2005 | 03:15 PM
Ah yes, it does have a front sway bar. Thanks for clearing that up. Do you know the diameter of the stock front sway bar, or as they call it, the stabilizer bar? Thanks for the help!
Old Jan 25, 2005 | 03:17 PM
jimbo74's Avatar
i odtn know the diamtere, but my 85 did indeed have a front swaybar, no rear though... i took mine off when i lifted my truck, i really didnt notice any difference with it off
Old Jan 25, 2005 | 03:26 PM
Flamedx4's Avatar
Says 1" for the 2wd Yota on the replacement bushing sites.
Yotatruck 1986 - a cheap mod that will help a lot - get some eurethane bushings for that sway bar. It'll tighten up that handling and with those shocks you'll have a handling demon.
Then, when money permits, get some aluminum rims (those look like steelies in the pic) - less unsprung weight on a 2wd helps too!
Old Jan 25, 2005 | 03:28 PM
jimbo74's Avatar
check out my rims, they are 15x7 and off of a ford explorer... there are so many around that you can probably find a set really cheap....
Old Jan 25, 2005 | 03:29 PM
Do you know where I can purchase some eurethane bushings to replace my stock ones? Thanks for the help.
Old Jan 25, 2005 | 03:30 PM
Flamedx4's Avatar
Correction:
It shows that the 79-88 2wd pickup came with either 18mm or 25mm front bar.
Ya gotta measure. 18mm is roughly 3/4" and 25mm is pretty close to 1".
Old Jan 25, 2005 | 03:31 PM
Flamedx4's Avatar
"Anywhere fine suspension products are sold."
Try Google...
Old Jan 25, 2005 | 03:38 PM
Is this what I'm looking for (They carry 18mm and 25mm kits)?
Old Jan 25, 2005 | 03:42 PM
Flamedx4's Avatar
Yep.
Shop around though, I think you can beat that price.
Also note that one brand has graphite impregnated bushings (they are black) which won't squeak over time. Might be worth it.
Old Jan 25, 2005 | 03:44 PM
jimbo74's Avatar
yup looks like it... if the swaybar is 1" think, then you want the 25mm bushings... as 25 mm is about as close as you can get to 1" standard
Old Jan 25, 2005 | 03:47 PM
Yep.
Thanks for all the help. I'll get the measurement of my sway bar sometime tomorrow.
One more thing, do you think a rear sway bar is worth the $150? Should it noticeably reduce body roll? Thanks again.
Old Jan 25, 2005 | 03:56 PM
Flamedx4's Avatar
Nah, not on a truck, unless you are gonna get into autocross or somethin'
Old Jan 25, 2005 | 04:13 PM
I probably will be getting into alittle AutoX. Also, I was wondering if you know whether or not a rear sway bar will bolt on, or do you have do drilling? Thanks again.
Old Jan 25, 2005 | 04:17 PM
jimbo74's Avatar
probably going to have to do some drilling at the minimum some fab mounting work or welding is a possibility as the axle didnt have provisions for it stock
