Audio question
Old Dec 26, 2002 | 08:11 AM
CBDenver's Avatar
Audio question
Happy Holidays Everyone!
Anybody here put a "door kit" in a 4Runner for sounddampening? I can't afford to do whole interior, but was thinking about doing the front 2 doors.
Any advice on products to use? Is it worth it? I've got resonating noises from bass in doors plus road noise.
Thanks,
CB
Old Dec 26, 2002 | 08:18 AM
Cool
Yah that name brand stuff is expensive....
I used Peel & Seal found in the roofing section of Lowe's.
6" x 25' roll, $9.99
You'll need 3 rolls to do both front doors.
You can do 3 layers on each door--the inside of the outer skin, the outside of the inner metal and the inside of the inner metal.
Then you can put some carpet padding in wherever you hear rattling or where the plastic door panel comes into contact with another surface. Use 3 M 77 spray adhesive for that....
Worked fine for me =)
Old Dec 26, 2002 | 08:24 AM
CBDenver's Avatar
Was it worth the work (LOL) to get rid of some noise? Did you do the floors or anywhere else, or just doors?
Thanks for the help. Did you have to heat that stuff up, or just peel and stick?
CB
Old Dec 27, 2002 | 07:48 AM
Yup I think it was worth it... there's less road noise. Door makes a nice THUMP when you close it ( you know, like a BMW or Mercedes, etc...)
I just did the doors right now.... Some people do the whole car, I'm not that anal and it is a big pain to remove all that stuff.... plus it's freezing out now hehe...
I didn't use a heat gun, some people do, some don't.... I'll let you know if the stuff falls off next summer...
Here's a link to a guy who seems to know what he's doing and he used peel & seal...
Peel & Seal demo
I guess it depends on how loud you play your music and how powerful your speakers/amp are.... But putting sound deadening on 2 doors is not that much work really...
Old Dec 27, 2002 | 09:23 AM
CBDenver's Avatar
Thanks for the info and that link! I think I'll try it as well since you recommend it. Do your doors rattle when bass hits? Mine do, I think I'll try the carpet pad idea too like the in the link you sent.
Thanks again for the information. Happy New Year! If you have any other advice, please feel free to give it!
CB
Old Dec 27, 2002 | 11:10 AM
Talking
NP, happy holidays
Yah the doors rattle when the 6.5" speakers hit low frequencies/bass.... I just recently finished my install and am fine tuning it now, so I'm in the process of taking care of the details (e.g., isolating points of rattling....)
Advice? Hmm...depends, what are you planning to install?
Also, that guy in that link--he carpet padded the WHOLE door. I really don't think there is enough space in the 4Runner door to put that much carpet padding in there w/o running into trouble putting the panel back on...
I just cut little squares of carpet pad and adhesed that on different spots -- you'll see when you remove the door panel that there are a few squares of padding there already that Toyota put on.... but what I do is listen to some music, figure out where it's rattling... and put the carpet pad at that spot if possible...
Old Dec 27, 2002 | 07:20 PM
trangk's Avatar
Partsexpress.com sound damping sheets
CBDenver:
Hey did you ever get your speakers in okay?
Anyways, like 4FonZ said, try the roofing sheets from Lowes. They are very effective and cost WAY LESS than Dynomat does. You can also try this link: http://www.partsexpress.com/webpage....7&WebPage_ID=3
I am using the asphalt based sheet (32" x 54" for only $19.00) and it works great. No more vibration in the doors. The sheet comes with a sticky side that you just press onto the door making installation really easy.
For inside the door, I use the spray type damping material cause it's easier to get in there and covers better than a sheet does. Then I use minimal expanding foam (3.50 a bottle from Lowes) to seal up any holes that air might escape out of.
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
Esibnitsud
Jul 30, 2015 08:19 PM
4Runnin2000
Jul 29, 2015 06:09 PM
