Crap! Who designed these rear shocks?
Old Dec 8, 2004 | 01:42 PM
DrummerDaveB's Avatar
I got my new Bilsteins, and Im trying to get the rear shocks off my 98 Runner.
How am I supposed to get the top nut off these things? :cry:
And why hasnt whoever designed these shock mounts been shot yet?
Old Dec 8, 2004 | 01:57 PM
there should be write up somewhere (maybe try JArunner site).
I think you need a 14mm deepsocket wrench up on top nut (it is a tight work space) and and an upon wrench to hold onto the hex on the top of the shock housing.
Old Dec 8, 2004 | 02:15 PM
eric-the-red's Avatar
If the old shocks are getting thrown away use a Sawzall and cut through the rod. I found that to be the the quickest way.
Old Dec 8, 2004 | 02:30 PM
midiwall's Avatar
When I did mine, I used a 14mm deep socket (as has been said) with a flex-head ratchet and a strap wrench on the housing.
It's a real pain, but "once you get the hang of it" you don't even have to take the wheels off!
Old Dec 9, 2004 | 11:17 AM
Bigkahuna808's Avatar
Like they said use the deep socket. It helps if your able to complety get under for best leverage. When I did mine I soaked the nut with seafoam penetrating fluid to make life eaiser. worst comes to wost, cut the damn thing off. At least destroying the old shock is fun.
Old Dec 9, 2004 | 12:54 PM
Adam F's Avatar
You still cant get the shock off if you cut the shock shaft in half. You would have to cut the top shock mount bolt off, and to get to that with a sawzall seems like next to impossible.
Old Dec 9, 2004 | 01:05 PM
914runner's Avatar
Dont ask how I mastered that one!
Old Dec 9, 2004 | 01:09 PM
anthony1's Avatar
You can always jack up the body........
Old Dec 9, 2004 | 01:16 PM
User 051420's Avatar
That makes it MUCH easier.. Now that I have the body lift, it's WAY EASY.
Old Dec 10, 2004 | 03:40 PM
Mad Chemist's Avatar
A socket up top, and a strap wrench on the shock body worked for me. Also, soaking the top nut for 3-4 days in PB Blaster helped quite a bit. Was definitely a pain though, good luck!
Old Dec 11, 2004 | 05:41 AM
gwhayduke's Avatar
Are the rear shocks on a 3rd gen any worse than a 2nd gen? I don't recall having any problems with my 2nd gen. Might be a "rust" problem.
Old Dec 11, 2004 | 05:56 AM
gn86r's Avatar
if you can get it loose enough, just spin the body of the shock while using the deep socket on top. after spending 30mins on the first shock the second one only took 5 mins. i searched this awhile back and that seems to be the easiest way.
Old Dec 11, 2004 | 06:24 AM
rimpainter.com's Avatar
Yep, the top nut SUCKS. The BL helped a lot, but that may not apply to you.
In addition to the above recommendations, I would also like to add a set of Mechanix gloves to the list; unless of course you like missing skin and grease in your blood
Yotadawgjr
10
Aug 23, 2015 10:51 AM
coffey50
Jul 28, 2015 10:55 AM
terminator
Jul 27, 2015 07:13 PM
Massmayhem247
Jul 18, 2015 05:46 AM
hangtown88toy
Jul 10, 2015 02:33 PM
