Brake Questions!
Old Dec 13, 2002 | 07:18 PM
data's Avatar
Senior Member
Brake Questions!
Does anyone know how to stop that dreaded squealing when I apply pressure to the brake. It will stop after a apply a certain amount of pressure. It just seems like when I'm lightly braking they squeak sooooo loud. I just changed my rotors about a month and a half ago.
Also does anyone know how to adjust the rear brakes more where they'll be utilized more than the front. I think my fronts are seeing most of the action when I brake.
Old Dec 14, 2002 | 07:14 AM
TDiddy's Avatar
Did you also replace the front pads when you did the rotors? I haven't replaced brakes on my 4runner yet, but going from past experience, there are shims or clips on some that help to reduce noise, and you can also but an anti-squeal compound. The squeaking could also be a sign that the pads are worn out.
Can't help you on the adjustment to set the rear up to handle more. I always thought the fronts did most of the work braking on most vehicles.
Old Dec 14, 2002 | 01:42 PM
data's Avatar
Senior Member
Nope I didn't replace the pads. I had them done about 2 months prior to me installing the rotors.
Old Dec 14, 2002 | 08:18 PM
tomus1000's Avatar
Your front brakes are always going to take the lions share of the work. When you decelerate, the weight transfers to the front. If you try to get the back brakes to do more work, they are just going to lock up.
fountain
Dec 31, 2015 06:08 AM
CanRunner
Jul 20, 2015 01:29 PM
Johntom240
7
Jul 13, 2015 12:18 AM
87turboPA
Jul 12, 2015 07:49 AM
87turboPA
Jul 9, 2015 05:58 AM
