How to get oil into the diffirential ?
I have been searching high and low for a oil pump .I just can`t find one in the Toronto area . I need a compact one to transfer the oil into the differential . Any help ?Or is there ajnother way to get the oil in there .
Where else besides Canadian tire can I get Amsoil ?I find that they don`t carry the differential and transfer case oil.
You know how gear lube bottles have the funnly looking "cone" nozzle on them? Well, you put a piece of clear tubing on the nozzle and the other end in your differential and then turn the bottle up and squeeze and you can see the lube going into the differential and you won't need a pump.
Go directly to the Amsoil website and you can order there. If you're planning on spending more than $100 over the course of a year then you'll definitely want to sign up as a preferred member.
http://www.amsoil.com
If you don't want to do that there are several members here who are dealers. Bob_98SR5 is one...
I just put the end of the bottle into the fill-hole, squeezed, and shazam!
Toyvana
Jul 29, 2015 10:47 PM
yourrealdad
Jul 29, 2015 11:08 AM
