Water Pump Replacement
Old Aug 4, 2004 | 05:00 AM
beachbrum's Avatar
Okay, so I have mustered up the nerve to to replace the water pump myself on my 81 22r 4x4. I ordered a waterpump online and now I am just waiting for it to arrive. Since this will probably be the closest to major maintenance I have ever done I have a few questions I am hoping you all can help me with.
First off, It appears the water pump I ordered will not be coming with a replacement gasket. Is it okay to use the old one? If not, does anyone know where I can order one through the internet?
Secondly, are there any tips for when I drain the radiator? The drain plug seems to be in a difficult spot and I don't really want coolant all over my garage floor.
Finally, I'd appreciate any input from people that have done this before on any model yota. I figure the more knowledge I have the better.
Thanks in advance!
Old Aug 4, 2004 | 06:33 AM
MODZILLA's Avatar
From: Bend, Oregon. 4mer Teufelhund, now a DoD Contractor
I would never re-use an old gasket, when draining the radiator make sure you have a 5 gallon bucket. If you want you can drain it by removing the lower hose, I'd leave the radiator cap on until I removed the hose. Once it's draining nicely then open the cap up. also when replacing the water pump you might want to install a new thermostat if it hasn't been done in a long time.
Charecter1
Nov 6, 2023 10:08 AM
mskalmus
May 28, 2017 07:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Avenged
Jul 9, 2015 07:55 AM
Jnkml
Jul 6, 2015 01:20 PM
