Brakes & Rotor Install/Question
Old Jul 22, 2004 | 01:54 PM
rshurden's Avatar
I am new to the site have been lurking for a while and finally decided to post. This weekend I am going to be putting new brakes on my 2001 Tacoma 4wd TRD. I am sure that I will need to replace the rotors while I am at it. I am going to get the performance friction pads. Where is a good place to get rotors besides the stealership. Are rotors easy to replace, I have never replaced rotors on a vehicle before. I didn't see a writeup maybe b/c it is so easy. If someone could give me a few hints it would be appreciated. I always like to be prepared when I start a job I have never done before. Thanks for the info.
BTW Toyota's Rock!!!
Old Jul 26, 2004 | 08:10 AM
amorphous's Avatar
hey mang....
it's VERY straight forward. For rotors...I got my Brembo's online...took about a week to get via ups...i don't recall WHERE I got them online...but if you search for it, you'll find the thread the link to the deal!
If you've done brakes before, your golden...the rotors just lift off, plop the new ones one....if you haven't done brakes I would recommend having someone with you that HAS....just to coach ya (and drink yer beer!) - or get a manual (and said beer) the night before and STUDY. I'm sure the web has tips all over the place as well.
I also recommend flushing your brake fluid....just get all new stuff in there...it's just a damn good thing to do...and you'll be taken care of for a couple years w/ clean fluid.
Don't forget to adjust the rear brakes....apparently that's a "cause" of warped rotors....the front brakes are working too hard and it puts more stress on the front!
Ă…aron
Old Jul 27, 2004 | 08:49 PM
motorhead99's Avatar
http://www.toyautoparts.com/ check these guys out.. discount oem parts
rock on,
matt
Old Jul 28, 2004 | 07:56 AM
Cooper04's Avatar
Brake Rotors
Be sure that you either use toyota or Brembo brake rotors. You don't want to use the Autozone type rotors ( cheap and warp easily). You should also use a toyota or ceramic brake rotor. Metallic Brake Rotors create too much heat and warp your brake rotors too easily. www.taylorautomotive.com is a good place to get stock brembo brake rotors and akebono ceramic brake pads. i have 35,000 miles on mine with no vibration yet.
Old Jul 28, 2004 | 09:04 AM
roger's Avatar
How do you know the rotors need to be replaced? I just replaced my pads at about 95k and the rotors were fine. Are you getting a lot of shuddering when you brake?
my advice is to check the rotor thickness and runout before you drop $$$ on new rotors...unless you already know for sure they are bad.
Old Jul 28, 2004 | 09:10 AM
rimpainter.com's Avatar
I disagree. My "Autozone" rotors have been great, and they come with a 1-year warranty. Not even Toyota could match that (due to thier install policy).
jashoeuh
Nov 18, 2024 08:08 AM
Leviticus6432
Nov 20, 2015 05:06 PM
ty1er
Aug 1, 2015 11:53 PM
ahriman
Aug 1, 2015 10:38 AM
rondogracing
Jul 14, 2015 07:00 PM
