Old Mar 30, 2016, 10:09 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tacoma Brake Guides
Print Wikipost
How to change the brake lines/hoses?
Old Jul 14, 2004 | 07:50 AM
schlopecki's Avatar
What does it take to change the brake lines?
1) bleed the system dry
2) change the lines
3) fill the system with the new fluid
How do you make sure you don't have air in the system?
Thanks.
Old Jul 14, 2004 | 09:05 AM
dogdenii's Avatar
Which lines are you changing?
We'll say you are taking off the drivers front.
Pick up a few brake line caps. When you disconnect the lines, you'll want to cap the lines that are staying on the truck so that you don't lose excessive fluid.
At the bottom, you'll cap the end of the caliper the same way.
KEEP AN EYE ON YOUR BRAKE MASTER CYLINDER THE ENTIRE TIME YOU ARE WORKING ON THE BRAKE SYSTEM. YOU DO NOT WANT THIS TO GO DRY!!!!
Take the caps off one at a time when you replace the line.
CHECK THE MASTER CYLINDER AGAIN
top of the master if it starts to get low.
Bleeding the brake system will either take a mityvac or 2-people "generally"
On person to open the line to bleed and the other to push the brake pedal to push the fluid/air.
You'll start with the rear brake proportioning valve, RR, LR, RF, LF
Old Jul 14, 2004 | 09:10 AM
schlopecki's Avatar
Thanks a lot - that's very helpful.
BTW I will be changing 4 rubber hoses - 2 front, 2 rear.
Rear - to accommodate to suspension lift, front - because I'm doing rear anyway.
Old Jul 14, 2004 | 09:15 AM
dogdenii's Avatar
http://www1.autozone.com/servlet/UiB...3d8016278d.jsp
This work for you?
Old Jul 14, 2004 | 10:22 AM
schlopecki's Avatar
Sure it works and sure it's helpful.
Thanks a lot Dogdenii!
Old Jul 31, 2009 | 12:28 AM
kurtdaniel's Avatar
Be very patient...Soak the lines very good with rust penetrant and try again. Yes the Rears are a pain. You might even need Heat to get them loose.. thats how to change a brake hose..
Old Jan 30, 2010 | 12:00 PM
dabshire's Avatar
how long does it take to Replace the rear Brake lines and does anyone have any information on how to do that?
Old Jan 30, 2010 | 02:05 PM
habanero's Avatar
A 10mm brake line wrench is very useful. 2 hoses up front, one hose in back on my 3rd gen 4runner, remove the rear spare to get better access. it's there at the diff. Same as the fronts except there's more steel line to get the air through when you're bleeding them.....make sure not to run your master cylinder dry.
Old Feb 20, 2011 | 09:08 PM
logsurfer's Avatar
Resurrection
Have you done this job?
it took me half a day, including the fronts and a trip to the store for more brake fluid.
Dont forget these; just in case something bad happens.
Attached Thumbnails How to change the brake lines/hoses?-vice-grip.jpg   How to change the brake lines/hoses?-lighter.jpg
Flying91
45
Apr 11, 2024 04:39 PM
Eggslinger
Jun 8, 2019 03:32 PM
jasonty
41
Dec 23, 2018 01:00 PM
fountain
Dec 31, 2015 06:08 AM
CanRunner
Jul 20, 2015 01:29 PM
