Need help! - just took off my skid plate...
Old Jun 23, 2004 | 01:12 PM
TBob's Avatar
and a big rubber gromet fell out and I don't know where it goes.
The truck is a 2003 tacoma extra-cab 4x4 TRD 5 speed.
Thanks,
TBob
Old Jun 23, 2004 | 01:20 PM
Tacoma Dude's Avatar
That's pretty vague... you got any more descriptors? Maybe even a pic?
Old Jun 23, 2004 | 01:28 PM
TBob's Avatar
OOPs realized I didn't put in when I droped the front skidplate -sorry
its about a 1" dia rubber gromet - fell out when I drop the skip plate.
Old Jun 23, 2004 | 01:50 PM
Any way you can get any pictures?
There are some pretty tech savvy folks here. Maybe they'll know just by the description
Old Jun 23, 2004 | 01:54 PM
My99's Avatar
My theory is that if it isn't a peice of broken/sheared off metal, it's probably nothing.
Old Jun 23, 2004 | 01:56 PM
rimpainter.com's Avatar
Sounds like something that was previously dropped on top of the skid. When you removed it, it fell out.
Old Jun 23, 2004 | 02:59 PM
TBob's Avatar
here are a couple of pic-
Old Jun 23, 2004 | 03:01 PM
TBob's Avatar
this is pic2
Old Jun 23, 2004 | 03:09 PM
Godzilla's Avatar
whats the diameter? that just looks like a firewall plug/grommet. check around the back of the engine wall for any holes that go into the cab. may have fallen out, though i dont know why it would be caught up in your skid plate
Old Jun 23, 2004 | 03:40 PM
I'd be interested to know what would need a grommet like that but not have something going through it.
Old Jun 23, 2004 | 03:41 PM
bulldog-yota's Avatar
This might help.
My 2003 4Runner has a couple of holes in the front skid plate that is plugged with these rubber plugs. I already lost a few in action, so dont worry too much. Check you skidplate(s) for holes that is the same in diameter. There are a couple towrds the sides and front of the front skid plate that might fit, check both sides of the skid plate you might see one hole plugged and one open.
Old Jun 23, 2004 | 03:44 PM
Godzilla's Avatar
i have a grommet like that in my firewall on the drivers side for my 4runner, nothing was going through it at all, just a hole with a plug. thats where i now run wires through from switches for my lights. its located down and to the left(toward passenger side) of my brake booster. most vehicles have them
Old Jun 23, 2004 | 04:54 PM
22Ryota's Avatar
Might just be me but kind of looks like a grommet for a pcv valve.
Old Jun 25, 2004 | 02:05 PM
platform389's Avatar
There are several of those in the cab area. Get underneath the truck and look up at the floor area carefully with a flashlight. One of the O2 sensors passes thru the floor on the passenger side to a connector under the seat. It uses a plug similar (...but NOT the same, has a wire going thru it...)as the pictured.
It is pouring rain here or I would go under mine and look around. Better stay out of deep water until you find where this came from. Life could get interesting otherwise.
Old Jun 25, 2004 | 03:05 PM
This will sound really nit picky, but that grommet - wherever it came from - is covered under warranty. Just a thought.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Aaronmarston
Sep 22, 2015 09:39 PM
AlexJet
Sep 14, 2015 09:00 AM
Peevedkitten
11
Aug 31, 2015 06:57 PM
