Reservoir shocks - a few questions
Old May 29, 2004 | 04:55 AM
Tacoma Dude's Avatar
Question Reservoir shocks - a few questions
Okay, so I haven't done a thorough search but I really haven't seen this topic covered all that well so I was wondering what people know about them. I've seen a few TTORA guys (as well as a guy up the street) who have these reservoir shocks going through their bed for the rear axle.
Exactly what is the added advantage? More travel?
How do you know when they need recharging or do they not and need straight up replacement?
Any further information, links, suggestions, comments (constructive type ) are welcome!
Old May 29, 2004 | 07:35 AM
85yota's Avatar
As far as I know, the advantage of using a reservoir is that you can use a shorter can length so you can get more overall travel. I have Fox Shox with reservoirs front and rear. I wasn't going to spend the money for them, but I got a great deal on some used ones when my neighbor was parting out his truck. You can completely rebuild the shocks if you need to. You can also get them recharged with nitrogen, I think mine are at like 200 psi. As far as I know, they will be the last shocks I'll ever buy for my truck.
-Justin
Old May 30, 2004 | 11:16 AM
So then how do you know when it needs recharging? And what's involved in rebuilding? New seals?
Sorry for the questions but I'm curious and don't really know where to go for information
Old May 30, 2004 | 03:53 PM
BruceTS's Avatar
The reservoir was designed to give the shock more fluid to help prevent shock fade from rough usage, like in desert racing. Another advantage is you can run a shorter bodied shock with a longer shaft for those tight fitting applications, like already mentioned. To recharge the shocks is just like filling your tires, but you'll need a nitrogen bottle; http://www.polyperformance.com/nitrogen_kits.htm , most are filled to 200 psi as a standard but a few go as high as 400psi. They are very simple to rebuild and easy to get the kit needed to do the job.
Unless your planning on jumping your truck, cutting a hole through the bed and mounting these shocks would be more for the BLING BLING look. Personally I wouldn't want to lose the storage space, when I get around to installing my new rear suspension, I'll be putting the short bodied, long travel with reservoirs tucked underneath.
This is similar to what I have planned;
http://www.aor4x4.com/esmrcbdir.htm
Old May 30, 2004 | 03:57 PM
I see, I see...
I hear that motorcycle shops can provide the refill if necessary?
Well anyway, so I gather then that when the shocks reach a certain lower PSI it is time to recharge? And this is guaged how? By height?
Thanks!
JaredL
Mar 28, 2016 09:08 PM
Luvmeye22re
Aug 4, 2015 03:53 PM
SMOD
Jul 27, 2015 01:45 PM
gmonnie123
Jul 26, 2015 02:44 PM
Massmayhem247
Jul 18, 2015 05:46 AM
