Steering play from 1st gen steering box
I recently replaced my pitman arm as there was play there. My idler arm is fine. I have limited the play to between my steering wheel and steering box. Is there any way to cure this. There are about 15 degrees of play. Thanks Seth
I don't know about 1st gen but on the 2nd gen there is an adjustment on the steering box for free play. There's a slotted bolt on top of the box with a lock nut. Undo the lock nut and screw in the bolt to reduce play, then tighten lock nut. Manual says 1 inch of movement at the rim of the steering wheel is correct.
Well, I just tightened up that bolt and it sure tightened everything up like you said. I have much less play now. Awesome. After that I just had to realign the steering wheel onto the right splines. That sure sucked without a steering wheel puller. But I got it done. Thanks for the wise words. My Chilton's guide didn't even mention such and adjustment. If I ever come across this chilton's character......I tell you. They took my 25.00 for the guide and 3/4 of the time they don't have an answer.
Troy
Jun 1, 2021 01:51 PM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
Jul 6, 2015 04:07 AM
