View Poll Results: How do you mount your Hi-Lift?
I use the Yakima brackets
18.18%
I use Hi-Lift's brackets
18.18%
I use readily available hardware
27.27%
I drag it behind the truck
36.36%
Multiple Choice Poll. Voters: 11. You may not vote on this poll
Old May 13, 2004 | 08:31 PM
SkyRat's Avatar
With all this "Slider Adapter" and "48" or 60"" talk around here, I have been curious...
Just how do you mount your Hi-Lift Jack. I have a Load Warrior with an extension and just have to get some input here...
I have seen Steve's (from his site)
I have seen Corey's (from his site)
But, what are everyone else's ideas?
I really want something with some security here...
Old May 13, 2004 | 09:42 PM
PoBoy's Avatar
$1.69 at the hardware store...just 2 bolts, 2 nuts, and a bunch of thickwashers. I basically just put 2 holes in the surco rack...plopped the highlift onto the bars and clamped it down with the bolts. You can see in the second picture that I had it resting on the Thule Bars and then bolted it to the Surco rack. I used large washers to acutally clamp it onto the lower support bar of the rack (its not just on the pannelling where I made the holes). Has worked excellently for over a year now. Cheap and easy...harder to get off than the other options probably, but definitely doable. If I still had the truck, Id take some better picks, but this is all I have of it:
Old May 14, 2004 | 03:20 AM
Corey's Avatar
Co-Founder/Administrator
Security as in theft proof?
I do not have any close up pics on my site right now, but I have posted them in the past.
You can drill right through the Slee bolts and then put a padlock through the hole.
You can kind of make out the padlocks here.
http://pnw4runners.com/runs/91402/251024.jpg
Hey, I did find some pics.
There is a good close up in my write up.
Old May 14, 2004 | 04:35 AM
jacksonpt's Avatar
Senior Member
Old May 14, 2004 | 04:37 AM
mt_goat's Avatar
Here is mine: http://community.webshots.com/photo/...05765089wzMtSE
It's in the bed over the wheel well in case you can't tell. Here is another view: http://community.webshots.com/photo/...05764865EiYpHG
Old May 14, 2004 | 08:58 AM
SkyRat's Avatar
Jackson, I see the pic but cannot tell just how it is mounted. What brackets did you use with the Surco?
Old May 14, 2004 | 09:04 AM
jacksonpt's Avatar
Senior Member
I have the brackets from Hi-Lift and the ones from Surco. Both work, but I'm not realy crazy about either. The Hi-Lift backets don't fit the surco that well, and I don't like the way the jack is secured to the surco brackets. I'm hoping to alter the surco ones just a bit to get the best of both worlds.
Old May 14, 2004 | 04:51 PM
SkyRat's Avatar
Well, I just received the REI Sale Catalog and found out that this is the time of the year when all Yakima is 20% off. That just might force me into buying these and having them delivered to my local store for free shipping.
kawazx636
Oct 6, 2021 03:03 PM
live4soccer7
May 11, 2016 06:52 PM
scott90
Oct 4, 2015 09:21 AM
voiddweller
Oct 2, 2015 07:47 AM
Brodetski
Sep 30, 2015 11:50 PM
