hey guys, long time no post but i wanted to start a thread on what may be a new and upcoming hot topic. flinstone fab has released his chevy traverse rear caliper mounts. i think i am the first customer to buy and install. i will add some photos later..but it looks like any other disc swap really.
his kit includes brake lines, a switch, and caliper mounts. you need to source 2018-2025 chevy traverse rear disc caliper, brackets, pads, and 4th gen 4runner rotors. why is this kit better than others? because it has an electronic parking brake, and it WORKS. no trying to rig up new cables or nissan ebrake handles, no line locks or track locks, and no wood blocks with a rope.
these brakes are beefy and stop incredible once blead appropriately. you mount a 2 way momentary switch in your cab, and run it to the rear calipers. you can run two switches and make some cutting brakes if you want. i ran one switch. hold the switch up and engage the brakes or hold it down to release them. you can check out my instagram for some videos in the meantime if youd like, keyappstate2.0 for anyone curious. this is far superior to the monte carlo setup i was using. more to come.
