Vendor Advertising Vendor's, use this area to alert members to your OEM & Aftermarket Toyota parts
Enhance Your Tacoma’s Performance With MagnaFlow
Old Jan 7, 2025 | 12:58 PM
carid's Avatar
Premium Sponsor
If you want to upgrade your Toyota Tacoma’s performance and sound, we’ve got you covered. The MagnaFlow SPEQ Series Stainless Steel Cat-Back Exhaust Systems are designed to deliver improved horsepower, torque, and a deep, sporty exhaust note. Built with high-grade stainless steel, these systems are durable and corrosion-resistant, making them perfect for both everyday use and off-road adventures.
The SPEQ Series exhausts feature mandrel-bent tubing for optimal exhaust flow, ensuring your engine runs efficiently and performs at its best. Whether you choose the MPN 19681 or 19680 model, you’ll get a precise fit and an easy installation process. Plus, their polished finish adds a sleek look to your Tacoma’s undercarriage.
If you want a reliable, high-performance upgrade that also enhances your truck’s sound, these MagnaFlow Cat-Back Exhaust Systems are a great choice. They’re built to last and designed to impress. Check them out and give your Tacoma the performance boost it deserves!
MagnaFlow® 19680 - SPEQ Series™ Stainless Steel Cat-Back Exhaust System with Single Side Exit
https://www.carid.com/magnaflow/speq...mpn-19680.html
Note: Choose your vehicle in the "Product Option"
Features
  • Exhaust Unleashed
  • Redefine your vehicle exhaust sound in all the right ways
  • Pure Performance
  • Engineered Excellence
  • Perfect Fitment
  • Includes all the hardware necessary for do-it-yourself installation
MagnaFlow® 19681 - SPEQ Series™ Stainless Steel Cat-Back Exhaust System with Dual Side Exit
https://www.carid.com/magnaflow/speq...mpn-19681.html
Specifications
  • Exhaust System Type: Cat-Back
  • Exhaust Tubing Material: Stainless Steel
  • Exit Location: Dual Driver Side
  • Main Tubing Diameter: 3"
  • Exhaust System Sound: Moderate
  • Exhaust Inlet Connection Type: Bolt-On
  • Muffler Quantity: 2
  • Muffler Body Material: Stainless Steel
  • Muffler Body Finish: Brushed
  • Muffler Type: Straight-Through
  • Tip Quantity: 2
  • Tip Finish: Black Coated
  • Tip Material: Stainless Steel
  • Tip Type: Double Wall
  • Tip Outlet Diameter: 3.5"
  • Tip Shape: Round
  • Tip Style: Folded Edge
  • Tip Cut Type: Angle Cut
  • Tip Attachment Style: Welded-On
  • Muffler Style: Tuned Chamber
  • Hangers Included: Yes
  • Clamping Type: Band Clamp
  • Clamps Included: Yes
To browse the full list of MagnaFlow products, follow the link below:
If you want to learn more about the MagnaFlow brand, go to this page:
https://www.carid.com/magnaflow/info/about.html
CoopMA123
Sep 2, 2023 09:06 AM
3VZRUNNA
Jun 7, 2009 11:44 PM
95_4MuddinSr5
Aug 17, 2006 04:17 PM
SuaveGato
May 13, 2006 09:41 PM
AznSky
50
Sep 12, 2003 09:51 AM
