I've been slowly working on an auto to manual trans swap on my 95 4runner. When I pulled the single pedal set out of the truck, I noticed that the base of the pedal set is the same. It is just minus the bracket that is stamped and welded. So, I'm going to cut it down and use the base as a template to drill my holes to mount the clutch master cylinder. Not sure why these Picts are so huge.. This is the one to be installed I'm gonna cut this one up to use as a template.
