Non-OEM Brake Boosters?
So the brake booster on my 2nd gen went out today and the stealership wants $1000 for the assembly (lol). Just wondering if anyone can vouch for reliability of any of the third party options?
There's this amazon special "PartsFlow" for $70:
Or there's remanufactured "BrakeBest" or "Cardone" from a couple sources: O'Reilly or YotaShop
Or there's this $300 one from "Yotamasters" which definitely feels like some random other one with their label slapped on... Yotamasters
Anyone happen to have experience with any of those or other suggestions? Ideally I don't want to do this again for another 280k miles
That requires a t100 master cylinder too though, right? I'm daily driving it and parked/working in the street, so hoping I can just bolt up a new booster without even having to bleed the brakes. I want to go to disks in the back eventually anyways, so probably save the master cylinder upgrade for then.
looking at your parts links, some of the t100 trucks use the same booster that your '93 v6 uses, so maybe i'm barking up the wrong tree? you already have better brakes, so where to get a stock replacement?
do you have the specific toyota part number? because this link says that the t100 boosters are discontinued: https://www.toyotapartsdeal.com/oem-...e_booster.html
i tried to filter by '93 v6, both results show discontinued.
the rockauto link: https://www.rockauto.com/en/catalog/...e+booster,1884
the cardone unit is much cheaper there, vs. yotashop
Not an exact part number no. The Toyota parts site shows "Fitment not available" for all their brake boosters. I'm like 95% sure it's some variety of PN 44610, though.
I think you're right, several listings show cross compatibility between T100 and V6 4Runner. I thought the T100 used a 1 1/16" bore master cylinder while the 4Runner uses 1", but maybe the booster itself is identical
the rockauto differences are new(2) vs. reman(the rest), and warranties.
the new skp warranty is one year? new cardone is limited lifetime, vs. all of the remans having shorter warranties?
cheaper with free shipping at walmart? same price as amazon: https://www.walmart.com/ip/CARDONE-N...yota/147316318
at least with the remans you should be getting toyota steel and toyota fit, and afaik some of the parts chains have a lifetime warranty regardless of what the manufacturer warranty is... pricing is all over the map tho.
