TRD Beadlocker Rims on 89-95 4WD Pickup ( Will they fit?)
Does anyone here know if TRD beadlock rims off a late model FJ or Tacoma will fit on 89-94 Toyota Pickup or 4Runners?
I've been looking all over the threads here and cant seem to find a definitive answer. Google doesnt have any answers either.
They're the same bolt pattern and the center bore is the same too... 139.7-mm. (5.5-in.) bolt circle and 106-mm. nominal center bore. About 99.99% sure the 4WD locking hub bore size is the same.
Looks like I found my answer:they will fit, no wheel spacers needed, but you will need to cut the inner lip off to allow it to fit over the locking hubs.
Tires used are 265/75 R16.
Thanks to @Shiryas for posting his work. Cheers!
