91 Toyota pickup brake actuator
1991 Toyota pickup SR5 5 speed 3.0 4X4 109k
replaced PS pump , lines , and gear box.
brake actuator started leaking from breather tube.
found a thread on a 4Runner form. Guy had the same issues. Was told to bleed the rear brakes to fix the issue. I did. Took truck for short drive . Breather tube started to drip again. Bleed brakes again. Still leaking from breather tube . Now it is starting to seep fluid where the 2 haves connect on the actuator.
need help trying to figure this out . No one has a replacement brake actuator on their sites. Is this thing rebuild able?
I just started seeing a couple threads saying to remove it and run longer PS steering lines and make a loop for the brake lines. Really don’t want to, but if I have to . I guess I’ll have to.
thank you for you time
helikyler
Jan 19, 2014 11:44 PM
