OME Suspension Parts Question
I finally found some OME rear leaf springs (CS019) for my 92 Toyota 4x4 pickup but I'm waiting on the bushing sleeve kit. Apparently there aren't any in the US! While I'm waiting, I'd like to go ahead and get the rest of the parts needed to install these springs. Do I need the new OME U bolts (OMEU53B) or will my stock U bolts work? I'd also like to get some greasable shackles. Can anyone help me with the correct kit? I think the OMEGS3 is the correct kit but got conflicting information from trailgear and had to cancel my order. Also, any shock suggestions with this setup? Any help is appreciated!
You will need longer U bolts. I went with the OME bolts and they fit perfect. I would recommend pinion angle shims too.
Have you checked ebay for the parts? That's where I got all mine.
For shocks I went with Rough Country because they were $40 cheaper at the time. They work fine you just have to make sure you get the right length.
