EGR Code 7 1
Old Sep 18, 2023 | 12:46 PM
crawlr's Avatar
EGR Code 7 1
Hi folks,
So got a rebuilt motor put in my 89 4wd truck, 22re motor. No check engine light (CEL) issues before. Now it lights up the CEL with 7 1 code after few miles of driving every time. I put a new EGR Valve, new Vacuum Modulator, new EGR temp sensor and replaced the vacuum switching valve, still same issue. EGR is working, as verified by smooth idle from cold and checked by local Toyota shop. The egr cooling plate was cleaned when motor was swapped. Old egr was plugged but for some reason CEL didn't light up then. Yes, a 10 ohm resistor is my last resort, but it seems this problem has happened to others, any advice/suggestions for me? Vacuum lines have been checked for correct routing. Appreciate it!
Carnut68
Aug 10, 2016 07:32 AM
markfagus
Jun 26, 2011 07:21 AM
shafner30
May 15, 2010 06:59 AM
95RunnerSR5
Jul 18, 2007 05:55 PM
jonwest7
Mar 2, 2007 08:40 PM
