Fluctuating RPM in GEAR After Oil Change - Code 14
Old May 3, 2023 | 07:28 AM
Wouldjaball's Avatar
1993 3VZE.
Did an oil and Transmission fluid change. Cleaned air filter...
Now once engine warms up and sitting at a light in gear, rpms fluctuate abnormally.
I have a new to me coil and igniter on the way as that's what Code 14 points to...
If that doesn't fix it... what are next steps with wiring?
I just find the timing odd...
Any other ideas on what might be causing this? I'm wondering now if a wire cracked in the harness or something when changing air filter...
Fluids all appear normal levels.
Old May 3, 2023 | 10:46 AM
millball's Avatar
Fluids not likely the issue.
Look to the Vane airflow meter wiring going to the air cleaner.
RockAuto
Vendor Advertising
Nov 13, 2020 10:58 AM
vooboo
Aug 1, 2012 07:47 PM
rearviewmirror
Apr 15, 2007 03:01 PM
pfbmgd
Nov 8, 2005 07:17 PM
