multiple sized thermostat options?
are there more than 1 size options for thermostats on the Gen 2 3.0? all the parts houses show the same size options, but when i go to install, even with the rubber gasket installed, the recess on the engine side is maybe 1/4" larger than the thermostat mating surface. this is causing a slight leak. when i took it off i noticed the P.O. added silicone to the piece you bolt on, assumingly to stop the leak i am getting. what gives?
Luca Signore
Jan 21, 2021 11:18 AM
mikeliz101301
Dec 24, 2008 06:39 PM
