Needing recommendations for buying a 22re head
Old Jan 21, 2023 | 05:35 AM
careercriminal's Avatar
I need to purchase a new head for my 22re that sits in my 94 truck.
I would like some recommendations for a reputable seller that you had purchased a head from and had good luck with the head.
Old Jan 21, 2023 | 07:21 AM
Jimkola's Avatar
YT Community Team
5 Year Member
My recommendation would be to get a bare head and transfer your oem camshaft, valves, etc
Lapping your valves to the head doesn't take much time, and all your used oem parts will be of vastly better quality than anything on a new loaded head.
Old Jan 23, 2023 | 06:15 AM
snippits's Avatar
I bought an Enginetech complete cylinder head from RockAuto 5.5 years ago for my 92 pickup with 22RE. It's still working just fine. The head was made in Taiwan. It was a complete head with cam, springs, valves, and etc. ready to bolt on. I did buy a set of Enginetech head bolts, and then used a Toyota head gasket.
Just looked at RockAuto, and the complete cylinder head from Enginetech is not available for your 94. ITM Engine Components complete cylinder head is in stock for $337.79. An Enginetech bare cylinder head is in stock for $185.79.
Old Feb 2, 2023 | 06:20 AM
alabowles's Avatar
I have one brand new OEM still in box
Old Feb 2, 2023 | 06:34 AM
Jimkola's Avatar
YT Community Team
5 Year Member
Toyota didn't sell assembled heads. Short block assemblies, yes. but not heads
Old Feb 3, 2023 | 08:43 PM
hillsteepler's Avatar
I bought a stock spec one from LCE in 2019, it looked like it was just a repackaged ITM head like Rock Auto has. Haven’t had any issues with it.
Old Feb 11, 2023 | 08:41 PM
semcoinc's Avatar
Last May I installed a ported and polished 22RE head with an RV cam from https://sunwestautoinc.com
I have about 6,000 miles on the unit and so far it is doing fine.
Mike
Old Feb 12, 2023 | 09:11 AM
Jimkola's Avatar
YT Community Team
5 Year Member
When someone installs an aftermarket 22R# loaded head AND has problems, the odds on favorite for issues is the camshaft. Most notably the lobes just getting ground down to nothing(rockers aren't terribly happy at this point, either) and sending debris all through the engine.
Now, I've read many theories, and some sound reasonable.
1) The cam material is inferior(soft). Good possibility. I think the rather involved break-in instructions that are recommended with these cheap aftermarket cams reflect this.
2) The springs are stiff. I compared used oem to new aftermarket and the aftermarket springs seemed much stiffer. but I had no accurate way of measuring just how much stiffer.
3) the valve lip on the aftermarket is thicker, along with the washer plater and retainer, making the spring even stiffer. in my case, those individual components were noticeably thicker. I didn't bother to measure by how much. The theory was the thicker pieces decreased the area where the spring goes, increasing the spring tension and increasing the resistance on the rocker. Sounds plausible.
Maybe if you follow the break-in instructions to the letter it tempers the cam.
i dunno. After dealing with one camshaft that got worn to hell in a few hundred miles, sending aluminum and steel debris all through my engine, I opted for installing used oem valves, hardware, and cam.
But, as mentioned, others have installed loaded heads with no issues. Jut be attentive.
Old Mar 5, 2023 | 07:27 PM
jazz1's Avatar
5 Year Member
That is exactly what happened to my sons camshaft..got ground right down at rear of camshaft. He thought maybe not heat treated. Forget who the seller was. I would have head done by local shop or reputable seller..cheap parts are for poor folks,,and ya know the saying "poor man pay twice"
Old Dec 12, 2024 | 02:52 PM
Ric L's Avatar
Do you still have this head, If so how much for it
Old Dec 12, 2024 | 02:57 PM
semcoinc's Avatar
Mike
My cylinder head and cam are still doing well with about 15,000 miles on it.
Mike
Old Dec 12, 2024 | 06:33 PM
Freewheel's Avatar
5 Year Member
Good job. How did you break it in?
Also, did you re-torque it?
Old Dec 13, 2024 | 08:31 AM
semcoinc's Avatar
This is what I did for break-in. I did not retorque the head.
  1. Liberally apply red tacky grease on cam lobes..
  2. Start the engine and immediately raise rpm to 3,000.
  3. Vary rpm between 1,500 and 3,000 for the next 20-30 minutes.
    1. Use a slow, steady acceleration/deceleration pattern.
  4. Shut down the engine and let it cool.
  5. Drain the oil and change the oil filter.
    1. This removes any metal particles from the break-in process.
  6. Refill the engine with 30W break-in oil.
The initial break-in is now complete. After the next 500 miles of normal driving, change the oil and oil filter again.
  • If you choose a synthetic oil, we recommend putting about 5,000 miles on the camshaft with conventional oil before switching.
Mike
Old Apr 29, 2025 | 05:22 PM
Jbreeze922's Avatar
Hey still have the cylinder head
still have it??
arcteryx
Apr 7, 2014 03:58 PM
utah
Jan 16, 2007 05:35 PM
tystoy
May 12, 2003 05:33 PM
