Head shaved 20 thou. Now I need a gasket.
I am getting so much conflicting info it’s confusing the heck out of me. I had a head gasket blown tool head to machine shop they pressure tested and took 20 thou off.
now I need to order a new gasket and new head bolts and im getting all kinds of answers on what to get.
some say thicker gasket, some say OEM gasket, others say truck will never be right without the LCE adjustable cam gear because my timing will be off.
does anyone have any similar experience with a machined head and care to share what you did?
I bought a new head because the wait was too long at the local machine shop.
Fel-Pro sells a shim that replaces the .020 that was shaved off your head. Also, .020 oversized gasket would be the other option. Check RockAuto for the oversized gaskets.
https://www.drivparts.com/part-detai...0Spacer%20Shim
I have bought NPR pistons that were milled short when manufactured, to accomodate decked blocks.
