89 Pickup 22RE compressor photo
Old Jun 22, 2022 | 03:42 AM
Daves89's Avatar
Good morning, Could someone please post a photo of their factory or dealer installed ac compressor so I an get an idea of what compressor manifold I will need? I have everything else. Going from aftermarket AC to factory or dealer setup. Thanks! Dave
Old Jun 22, 2022 | 06:27 AM
JoeS's Avatar
My 1986 2WD truck takes a Denso 10-P 13-C compressor. It's runs on R-12 still.
Old Jun 27, 2022 | 04:51 PM
Daves89's Avatar
Joe any chance you can snap a good pic of the manifold on top?
Old Jun 27, 2022 | 06:21 PM
JoeS's Avatar
I'll snap some pics tomorrow after the rain stops. I've been looking for replacements as well and have yet to find any like mine.
Old Jun 28, 2022 | 08:31 AM
JoeS's Avatar
These are the best I can get. Cant get overhead as too many engine parts in way. This is from a 86 Toyota Truck 2WD OEM AC.
The high side (left) manifold is separate and different from the low side (right) manifold. I have searched the internet for these exact ones and have not found them anywhere. Even on specialist web pages. Good luck.
RockAuto lists the 89 22RE ac compressor as a 10PA-15C. Mine is a 10P-13C.
Old Jun 28, 2022 | 04:15 PM
JoeS's Avatar
I did see this picture of this Denso 10P-13C with a Low side (right) manifolds that look similar to the one on my compressor. The high side (left) does not. https://www.acparts.com/product/denso-10s13c-reman/
Old Jun 29, 2022 | 08:21 PM
aztoyman's Avatar
I have a 1990 I can probably get a pic of tomorrow if it will help. I just converted it to R134A and the high side charge port sticks out to the passenger side toward the battery. The low side charge port points rearward. That I remember. They suck to get to to charge the A/C. I have to pull the battery, hook up the hoses and reinstall it.
Old Jun 30, 2022 | 04:51 PM
aztoyman's Avatar
Here's a couple pics of my 1990. Best I can get without pulling the battery.
Old Jul 7, 2022 | 04:38 AM
Daves89's Avatar
Nice photo! Thank you! Now that manifold looks to be one piece? I'm wondering if Toyota changed to the "peanut" style fittings instead of the threaded fittings in 88 or 89.
Old Jul 7, 2022 | 04:40 AM
Daves89's Avatar
I will order a suction hose from my Autozone and see what shows up. If I remember when I talked to my commercial acct guy he said he could only get the suction hose.
Old Jul 7, 2022 | 08:57 AM
aztoyman's Avatar
You can cut the aluminum crimp off and reuse the fitting if you find hoses in a junk yard. It's basically just a barbed hose end. Just cut the hose to get the fittings. That's what I did when I swapped a 3.4 into my 88. I used the 3.4 compressor and fittings and connected to the original 88 system fittings. I just cut the aluminum sleeves off and bought the hose I needed. I just slid the hose on over the barbs, marked the orientation in case they rotated on the fittings, and took the hoses into a shop to get them crimped. Maybe you already know this. Just putting it out there.
Old Jul 8, 2022 | 08:40 AM
Diesel and Dust's Avatar
Hello
Daves89
Jul 14, 2024 06:37 PM
spazman
Dec 6, 2021 07:45 AM
Lando
May 15, 2021 09:38 PM
Neil McCon
Jul 1, 2013 08:32 AM
csharp100
Jun 29, 2009 07:05 AM
