22RE AFM idle question
Old Apr 23, 2022 | 11:49 PM
musician235's Avatar
I just bought a 92 pickup with a recently new engine but it has very black sooty exhaust enough to leave a black smudge on the ground at idle for two minutes. The previous owner was replacing O2 sensors frequently and finally gave up on the truck.
I ohmed the AFM and it was all within tolerance except for one of the tests where it was about 20 ohms below the tolerance.
I opened up the AFM and dialed it a few notches clockwise to lean it out but now the idle has increased, but there is less black smoke.
When I turn the truck on now, The idle is low, But as the truck warms up it begins to idle surge.
When I unplug the AFM everything begins running perfectly, the black smoke goes away and there is a low even idle. Of course I can’t run it that way because pushing the gas pedal cuts the motor out without the AFM plugged in.
Does the apparent resolution when I unplugged the AFM point to a faulty AFM, or are there other possibilities ?
I am reading a lot of the postings trying to learn everything but have reached a frustration point. any advice would be appreciated
Thanks in advance!
asumtneer
May 1, 2013 02:24 PM
93YotaGuy
Aug 21, 2009 08:05 PM
Junkers88
Apr 9, 2009 04:51 PM
swerks
Apr 28, 2008 06:00 PM
jt94130
Sep 26, 2007 08:37 AM
