1990 4Runner real wheels will not engage
Old Jan 24, 2022 | 04:13 AM
Anew311's Avatar
I have a 1990 4Runner SR5 3.0L V6 4X4. When I I’m in 2H or 4H you can feel the transmission go into gear but no power to the real wheels. It slowly moves but the. Reva high like in neutral. If I put it in 4L it will move.
any thoughts to why this is happening?
Old Jan 24, 2022 | 05:13 AM
scope103's Avatar
Welcome to YotaTech. We're more likely to be able to help you if you tell us something about your vehicle. I'm going to guess you have the A340H automatic transmission (it's on the sticker on the driver's side door jamb). Your transfer case is part of the A340H, and it's really a small automatic transmission itself, http://web.archive.org/web/201408160...28operatio.pdf How did this problem first come up? (What happened?)
I'm no transmission expert, but from your description it sounds like your Transfer Forward Clutch (C3) is shot. As in, start checking salvage yards for a replacement transmission.
Old Jan 24, 2022 | 10:06 AM
Anew311's Avatar
As for the transmission information I’ll have to check. It was recently towed and then it stoped working.
Old Jan 24, 2022 | 10:23 AM
COMTB's Avatar
Flat towed? Towed behind a wrecker with the rear wheels on the ground? Completely up on the tow truck? Were the trans and tcase into N if it wasn't completely off the ground?
Old Jan 24, 2022 | 10:36 AM
Anew311's Avatar
I think flat towed and in neutral
Old Jan 25, 2022 | 06:32 AM
COMTB's Avatar
Hmm if you get under and spin the drive shafts by hand with the wheels on the ground what happens? Both with the truck in N and in D (can try R too).
Kelly Sharpton
Jan 16, 2020 10:16 PM
muddfreakm
Oct 22, 2018 02:21 PM
Jimbone
Sep 17, 2013 04:21 PM
SunFox
Nov 19, 2006 10:56 AM
